Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Designing Kitchens and Bathrooms
Reload this Page >
Install glass mosaic backsplash over glossy paint in kitchen???
Old 02-15-12, 05:33 AM
B
We are planning on installing a glass mosaic backsplash in our kitchen, which is currently painted with a semi gloss paint. We were told that the glass tiles would not stick to the glossy paint and the options we have are to either install backerboard or underlayment to the area before using the thin set mortar. Are these our only options??
Old 02-15-12, 10:58 AM
H
Received 9 Upvotes on 9 Posts
Rough up the semi gloss paint with sand paper to take the gloss off. Clean off the residue and paint with a flat latex primer. You can then install the glass tile. Make sure you used the glass manufacturers recommended installation method and setting materials. Check out their website
Old 02-15-12, 11:04 AM
Gunguy45's Avatar
Super Moderator
Received 7 Upvotes on 7 Posts
Someone needs to use that Bondura stuff and let us know how it works......
The OPs project is exactly what I've seen it recommended for...
Old 02-15-12, 01:54 PM
H
Vic keep in mind that you can see thru the glass, and so you will see the color of the bondera. This stuff is kinda like setting tile with double sided tape if you ask me.
Note to op, your glass manufacturer should have specific installation instructions to folllow for their glass tile.
Old 02-17-12, 05:57 PM
B
Thanks a lot for your help!!!
