bathroom floor
Old 03-25-12, 08:41 AM
B
bathroom floor
Howdy! i am about to renivate a small bathroom. the only question ihave (so far) is what to do with the floor. it is currently tile on cement slab. should i bother trying to remove the existing tile or go right over it?
Cheers!
if i should just go over it, what would the prep steps be?
Old 03-25-12, 10:12 AM
chandler's Avatar
Received 6 Votes on 6 Posts
What type tile, ceramic, VCT, linoleum, large squares, small?? Got any pictures you can post? http://www.doityourself.com/forum/el...your-post.html
Old 03-25-12, 10:53 AM
B
larry--here are 2 pics. it is small ceramic (i think) tile.
Cheers!
DSCN1380.jpg picture by birch69 - Photobucket
Old 03-25-12, 11:53 AM
chandler's Avatar
That helps, thanks. Although you can tile directly over the existing tile, you will need to be aware of the plane change in height to the next room. A transition will be needed. Do you plan on doing anything with the wall tile, sink and toilet? If you remove the walls, you can add blocking for a new hanging sink and do away with the vertical supports.
Old 03-25-12, 01:05 PM
B
Thanks again..I am planning on gutting everything except the shower and shower walls. It is a tiny space and getting rid of the sink supports will b good. Probably go with a small pedestal. The current floor is actually 1/4" lower than hallway tile for sum reason so going over would work out ok. Would I treat the existing tile like a subfloor and just lay tile or is there a prep that is required to overlay?
Cheers!
Old 03-25-12, 05:06 PM
chandler's Avatar
If you can rough up the surface of the tile, it would give the thinset a better place to adhere. From what I have experienced with this type and age of tile, you may have a concrete base under the tile, rather than just wood with backer board like we use today. The concrete base may be as thick as 2", so let sleeping dogs lie.
