Laminate Countertop Replacement
I want to replace my u-shape laminate kitchen countertops. What's the going trend? Is using preformed countertops with 45 degrees already cut OK? I suspect having a cabinet shop fabricate a large u-shaped countertops would be quite costly but I may do that if exposed seams are definitely a bad idea. Thanks for your input.
Laminate countertops aren't all that expensive and the big box stores can do a good job with these.
The going trend? Granite.
My personal preference? Quartz.
If either part of the U is used as a bar, there are special pieces that must be incorporated. If it is enclosed on all three sides, then you're good to go. I have removed all my laminate and installed marine plywood, concrete backer and 12" slate look tile without a grout line (or small), then banded it with oak. Rugged and looks good.
