Shower door falling off the rails
Old 06-03-12, 01:30 PM
I have an 'older' shower door unit (3 doors on rollers) and the doors keep falling off the rollers. The bottom of the doors have a 'flange' that secures the door to the frame. Why are the rollers falling off of the frame? I cannot replace the unit at the moment so I need a quick fix.
Thanks
Old 06-03-12, 04:24 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
It is possible the roller adjustment is off a little. The bottom rail isn't moving, so the rollers have to rise up, and consequently fall out of the track. You will probably see a screw that holds the roller to the door, and it is through a slot. Loosen the screw and lower the roller a little.
