Bathroom Re-Do
Old 10-25-12, 02:23 PM
Bathroom Re-Do
I am remodeling a bath in a 100 yr old house.I had to gut the room old plaster lathe etc...I also need to replace subfloor. I plan on installing tile floor.What should I use for sub floor Also,I plan on a shower unit.Should shower unit be installed before tile floor or on top of tile?
Old 10-25-12, 02:51 PM
Received 47 Votes on 44 Posts
Welcome to the forums.
Shower unit separate from the tile unless the tile is part of the shower.
That said, let's back up - what's the size, spacing and unsupported span of the floor joists?
Old 10-26-12, 10:32 AM
Well I haven't got the old floor removed yet,My plan is to check plumbing under floor because this was a problem with old clawfoot tub.The new shower unit will be where the tub was and I will probably also need help with the drain for shower,getting it to main drain pipe.I am pretty overwhelmed with this job so far.I know I can do it,I just can't afford professional installation at this time.I can't turn back now.
Old 10-26-12, 10:43 AM
One additional question - you're not removing the only tub in the house, right?
Old 10-26-12, 11:14 AM
Received 15 Votes on 15 Posts
Starting from the begining...
What level of your house is this bathroom on and what is under it?
What problem with the piping did you have with the old tub?
Are you putting the toilet and sink in the same location as previous?
Old 10-26-12, 12:13 PM
Yes,It's already out.Will sell it to fund some of the redo.
Old 10-26-12, 12:29 PM
Bath is on second floor.Under it is front door entrance and hallway.Old tub would drain very slowly at times...would unclog it and it would be ok for awhile.Did not leak.My son broke the drain trying to snake it and I could not fix it so.I was going to redo everything so I started.Tub was first to go.I can see from partially removed flooring that tubdrain pipe was stainless like for a sink...Not right. Toilet and sink will be in same location.
Old 10-26-12, 12:34 PM
If you lived closer, I'd be asking for pictures and how much.
Old 10-26-12, 12:39 PM
Its in pretty rough condition...what you think I could get for it?
