Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Designing Kitchens and Bathrooms
Reload this Page >
Question reagrding Vikrell tubs and tiling the walls.
Old 11-14-12, 08:24 PM
I am now considering using a Sterling Vikrell tub in my remodel job. Can I tile the walls after installing this tub? Thanks!
Old 11-15-12, 02:41 AM
chandler's Avatar
Vikrell is the material Sterling uses to make their tubs. Which style were you thinking of?
Old 11-15-12, 04:37 AM
The Vikrell All Pro bathtub.
Old 11-18-12, 02:08 PM
chandler's Avatar
Yes, this tub will allow you to tile above it. You will need to install 1/2" concrete backer underlayment on the walls after a vapor barrier. The cbu will protrude slightly past the lip on the tub, but that's ok. Your tile will cover that gap when you install it.
Old 11-18-12, 05:36 PM
Long story, wound up with the Kohler Cast Iron from my local plumbing supply house. Thank you!
