Tub Caulking Pin Holes
Old 01-07-13, 05:37 AM
Received 15 Votes on 15 Posts
Over the weekend, I removed the old caulking around the tub and replaced it. Being a pretty straight forward task, and not being my first time, it should have been easy and pretty flawless.
Somehow I ended up with small pin holes in the calking.
The steps taken was as follows;
- Remove old calking (knife and paint scraper)
- Clean area with alcohol wipes.
- Use hair dryer to dry area
- Run bead of Mono kitchen and bath caulking
- Smooth in/press in with finger
- Allow to dry for 24 hours
When I checked on the job ~12 hours after the fact, there was half a dozen small pin holes in the caulking in a various areas around the tub. Oddly enough, most where in areas that required ~1/4" bead were other areas that required very little where fine.
This has never happen to me before. The only thing I can think of that was different this time was the really low humidity.
Any ideas as to why or how this could have happen?
Old 01-07-13, 05:51 AM
Received 120 Votes on 107 Posts
Not sure about the why, but are the pin holes deep? or just on the surface?
I'd probably just smear a little bit of caulk over the holes. The biggest concern is the bond between the tile and tub. If there aren't any cracks on either side - it should be fine.
Old 01-07-13, 06:02 AM
The holes looked to be through the caulking. The caulking was used to seal between the tub and the plastic surround.
I added more and pressed it in lightly, filling the holes. No issues after the fact.
I've never seen this before, so I was just wondering if there was something I didn't know.
