Mortar will make tiles stick out too far
Old 01-11-13, 07:30 PM
B
I am redesigning a bathroom and got a tub which has no side to it. It could be a drop-in surround, but due to space issues I am unable to do that. Instead I have put a sheet of hardibacker attached to plywood up as the side and am planning to tile it. Because of this, the tile needs to end up flush with the lip of the tub. Unfortunately I cannot push the board back any farther into the underside of the tub and the tile will be just flush as it is now. If I add mortar, it will be sticking out. Is there any adhesive I can use besides mortar that would have minimal depth to it?
Old 01-11-13, 07:57 PM
XSleeper's Avatar
Received 895 Votes on 821 Posts
what size hardibacker did you use? 1/4"?
Old 01-12-13, 06:06 AM
GregH's Avatar
Super Moderator
Received 51 Votes on 48 Posts
I have a small whirlpool tub that did not come with a face panel.
It is made so that a 2x2 frame will fit under the tub lip and is fastened to the wall and floor.
The instructions for this were in the tub's paperwork and I suspect the mfr of yours also has some sort of plan for closing in the front.
What do they suggest?
Old 01-12-13, 03:20 PM
B
Yes, 1/4" hardi. They recommend placing it as a surround which I normally would have done but unfortunately it is a small bathroom and the dimensions will not allow that.
Old 01-12-13, 09:04 PM
XSleeper's Avatar
I was hoping that maybe you used 1/2" hardi and could use 1/4" instead.
You said you placed it over plywood. Maybe the plywood should have been 1/8" thinner, such as 3/8" instead of 1/2"?
Old 01-21-13, 08:53 AM
B
I think that's probably how I'll have to do it. Thanks for the suggestion
Old 01-21-13, 09:16 AM
B
Can you not skip the plywood and just put 1\2" backer on it. If you do have to come out 1\4" you could use a metal tile edge. You will just see an edge of metal trim
