Seal tub to floor tile
Old 04-09-13, 04:33 PM
D
Should I run a bead of sealer over the grout at the edge of the tub? Just got this new porcelen tile installed. I would think the grout is a good enough seal.
Old 04-09-13, 04:59 PM
chandler's Avatar
Received 5 Votes on 5 Posts
Nothing ruins a good tile job more than ill placed caulk or sealant. If you choose to place a bead of sealant, use a color coordinated sealant to your grout. Most box stores have an assortment. Small beads are better than goppy ones, so clean it as you go.
Old 04-10-13, 03:17 AM
D
Thanks. So is it recomended to use a seal at the tub? I guess if the grout cracked there the seal would prevent water getting in the crack.
