Replace the Surface-Mount Medicine Cabinet?
Old 04-26-13, 03:22 PM
B
How do replace the Surface-Mount Medicine Cabinet and plus I saw the paint around the medicine cabinet in the bathroom?
[URL="[URL="http://ecx.images-amazon.com/images/I/31d9ezOPtTL.jpg"]"]
Old 04-26-13, 03:25 PM
Nashkat1's Avatar
Received 6 Upvotes on 5 Posts
Your link goes to an image of a flush-mount medicine cabinet. What is your question about the paint?
Old 04-26-13, 04:01 PM
B
how do I remove the paint before removing the medicine cabinet?
Old 04-26-13, 04:20 PM
Nashkat1's Avatar
How do you remove what paint? You said you have a surface-mounted cabinet. Those hang on the face of the wall. The paint is behind them.
A flush-mounted cabinet may have a bead of caulk around it which can be cut with a utility knife.
Old 04-27-13, 04:28 AM
Received 871 Upvotes on 762 Posts
Perhaps a pic or two will clear things up - http://www.doityourself.com/forum/el...-pictures.html
As stated above a utility knife can be used to break any bond[or caulking] the cabinet may have with the wall.
