Tin Tile back splash over Formica
I agree with Z on the holding ability of the screws. You can use a good adhesive like PL Advanced, or other high quality adhesives in a tube and spread it with a v notched trowel and the panels will stand a good chance of remaining on the formica. Other than that, I believe the manufacturer's suggested adhesives may fail.
I currently have a Formica backsplash which extends accross an 8' counter and
goes up the wall about 2'. The Formica is partially behind some cabinets and
is in good condition except in the middle 2' where it is starting to seperate at the top from the wood backing. It's held firmly in place at the outer edges because of the cabinets. Is it a good idea to reglue and/or screw down the center area where the Formica is coming apart and then glue on the tin tile backsplash? The tin backsplash is just going to cover the center area of the formica.
The formica is usually glued to particleboard. Make sure that the particleboard did not get wet and expand as the reason for the delamination. Its also usually glued with a contact cement.
Not sure I follow where the tin panels are going? Center over just the patch? Center horizontally across the whole length?
The tin is going over the middle 4' of the 8' length Formica that isn't under cabinets. The tin will butt up against the sides of the cabinets. I can't tell what's under the Formica or whether it's expanded fiberboard. The Formica that is under the cabinets is being held firmly in place and looks like it will last as long as the cabinets. As can be seen in the photos there is a seem and the top portion of the Formica isn't coming apart, just the lower part in between the cabinets. The tin is just leaning against the Formica to give an idea of positioning.
It is actual tin or metal that the panels are - correct? Not the plastic panels I see on display in the big box stores near the kitchen displays. Concerned about flammability in proximity to the cooktop as there is already staining from heat which is probably why it is delaminating.
What's in the picture is a plastic panel from big box, just got that to get an idea of how real tin will look. Will eventually use real aluminum. Could I use screws to tighten down the section that the tin will go over?
Devils advocate here only
The metal panels you are going to put up will dent when you slide that big pot of pasta water onto the burner and accidentally bump the wall.
Particle board does not have tremendous holding power so the long term success of screwing it down are questionable. Particularly a section of particleboard that has been subjected to heat on a regular basis as yours has. It is already telling you it is fatigued through delaminating.
I took a picture of the board at the back of the cabinets. I was
able to look down the Formica that's coming unattached and it looks like
the same material, though it was hard to get a really good look. Doesn't seem to be particle board. Couldn't I find studs to
attach to? The house was built in 1962, don't know what materials were typical then. The board behind the Formica measures exactly 9/16th".
