Tiling over cultured marble?
I have tiled over ceramic tiles, but NEVER over large cultured marble panels.
Any thoughts on doing such?
Thanks,
Dale in Indy
Thanks,
Dale in Indy
Not sure where you are going as your post is rather vague. If you want an opinion from me, it is not whether you can, but whether you should. I'm all about doing the job right from start to finish. I always think in terms of starting with the correct base and building up from there. If you are not willing to remove to start from pristine, why bother getting direction from a forum designed to guide you in the correct way. Extend the effort and remove whats there and build up correct. Tile is not like a coat of paint that you can apply over another. It requires planning and preparation.
