trouble with a shower pan
I need help!! I installed a cultured marble neo angle shower pan and walls in my home. While I was finishing up the project the shampoo and soap holder fell off and cracked the pan. I have removed the pan but the panels are still on the wall. I need ideas on how to either install a new pan or build one from scratch without damaging the two panels. Another problem is my floor is unlevel as it falls over an inch in the 42 inches...thanks
DW - we will need a little more to go on that this. Do you have some pictures to share? http://www.doityourself.com/forum/el...-pictures.html
I can picture the cultured marble pan, but not what you did with the walls. Also, not sure how the soap dish would just fall off.
Usually you take care of the unlevel flooring before you begin your build. That is a pretty big drop off by for a floor that is supposed to be flat.
