tile over formica for a kitchen backsplash
Old 02-27-14, 03:52 AM
C
Hi!
I am looking to die a cosmetic update to my kitchen by upgrading the backsplash from the exisiting formica to a tile backsplash. The formica is in good shape without any obvious joint seperations, bubbling or delaminating so my question is do I need to remove it and install a backer board or can I tile rightover the top of the formica? would the adhesive hold adequatly to formica?
Thanks for any help.
Old 02-27-14, 05:16 AM
P
Received 1,849 Upvotes on 1,655 Posts
The plastic laminate should be removed. For a back splash you may be able to apply it directly to what's behind but the laminate should go.
Old 02-27-14, 01:14 PM
C
What is the best way to remove the laminate from the walls? Mine seems to be glued on pretty tight and I'd be afraid of damaging the sheetrock\gypsum board.
