Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Designing Kitchens and Bathrooms
Reload this Page >
New granite backsplash too tall to fit under wall-mounted mirror...advice please
Old 03-25-14, 10:45 AM
R
I am replacing a formica vanity top/backsplash with a new granite vanity top & backsplash (store-bought, not custom). The new backsplash is 1/4 inch higher than the formica backsplash, and it won't fit under the wall-mounted mirror. I want to keep the mirror, but can't remove it from the wall without breaking it. Should I cut the mirror, or bring the granite backsplash somewhere to be trimmed? This is a DIY project, and I don't have a tile/granite saw. Thanks for any advice!
Old 03-25-14, 02:40 PM
P
Temporarily Suspended
How would you cut the mirror without breaking it. I would have the back splash trimmed.
Old 03-25-14, 03:14 PM
P
Received 1,840 Upvotes on 1,647 Posts
How big is the mirror? It might be cheaper to take it down even if it breaks it and replace it with another mirror or something totally different?
Old 03-25-14, 05:17 PM
czizzi's Avatar
Go to the plumbing dept at the box stores and look for a "wire cutter". I is a length of stranded wire with covered/insulated loops at each end. In plumbing it is used to cut PVC pipe in tight places with a back and forth sawing motion. Slip the wire behind the mirror and gently scissor the mastic off the back side of the mirror to remove. Then re-install the mirror at the revised height.
Old 03-26-14, 08:44 AM
R
The mirror is 37" wide, 42" tall and 1/4" thick. To the right of it is a wall, and below it is the formica backsplash (the old fashioned, one-piece counter with attached cove backsplash). The mirror is attached to the wall with adhesive of some sort. It is a nice mirror and I don't want to take it down or replace it. Trying to do a simple bathroom update with new paint, vanity top & fixtures only.
Old 03-26-14, 08:57 AM
R
Does anyone know what kind of business I could take the granite backsplash to, which would trim the backsplash 1/4 inch ? And, approx. how much should it cost (it is 3/4" thick, 4" high X 37"wide--need it to be 3 3/4"H X 37"W). I am new to the area where I live and do not know any handymen.
Old 03-26-14, 09:13 AM
Received 753 Upvotes on 658 Posts
I know very little about working with granite but I'd think any place that sells it would either be able to cut it or send you do someone that can.
Old 03-26-14, 01:58 PM
P
A tile place should have a wet saw. I wouldn't pay more than $50.00
