Kitchen Tile Backsplash
Old 04-10-14, 08:42 AM
W
I am looking to repair this issue very quickly and need your opinion. As you can see in the attached pics, my granite counter has separated from the tile backsplash and split the grout line. This is an issue all the way around the kitchen. What can be done to fix it? Thank you
Sincere Homeowner needing help
Old 04-10-14, 10:16 AM
Received 1,197 Upvotes on 1,152 Posts
Welcome to the forums.
I'd scrape out the grout and caulk the joint instead.
Old 04-10-14, 02:13 PM
Received 756 Upvotes on 661 Posts
I don't know if it's available elsewhere but tile stores sell an array of sand finish caulking to match most grout colors.
Old 04-10-14, 04:59 PM
czizzi's Avatar
Grout does not belong there, it should be a flexible caulking as others have mentioned. If you know the color and name of the grout, you can get a matching caulk that will blend from a tile shop. You can try caulking over the crack and see if it holds before going through the effort to dig all the grout out and chance scraping your granite.
