What size of support bracket do I need for my bathroom slab vanity?
I have in mind two versions, from SpeedBrace - FastCap - Woodworking Tools
- 15" x 18"
- 8" x 12"
I assume part of your stone will be overhanging the cabinet??? How far is it overhanging? The distance will determine how large a bracket you need. You also need to be concerned with where the bracket will mount. Most cabinets are not strong enough to offer much support if you just screw a bracket to the cabinet's flat side.
We use Fast cap brackets quite a bit in commercial work, and they do really fine. I like the channels they run for wiring, etc. Of course you won't need all that. They hold quite a bit of weight, but as Dane says, you must attach it solidly to a stud. Use the larger one. You can put which ever dimension on the wall that you feel will hold the weight. Epoxying it to the top surface of the brackets may be sufficient.
At this point I have two of the 15" x 18" FastCap brackets. So, I'm guessing the best arrangement for this would be to have both mounted on the top wall. Then have the stone epoxyed directly to the top of the mounted brackets with no other work done and I should be golden.
15 x 18 is a little "pimpy", IMO. I like the longer side to fasten to the wall and the short to the top, so you could go with a 24 x 18 for super support. What you suggest, however is spot on.
To the right of the diagram I drew is the toilet - which allows a small space on the wall for a toilet paper holder, but it isn't an optimal area to reach from the toilet. If I wanted to mount this on the stone's miter, would there be a type of adhesive I can use (the alternative being drilling into 3cm of stone)?
I would use a two part epoxy for gluing. If you want to just test fit something to see how you like it hot melt glue works well and is easily removed.
I would glue a toilet paper holder to the bottom instead of trying to stick it to the side. First of all you'll be more limited trying to find a holder that looks good with a base that's less than 3cm wide. Then the polished and possibly sealed edge of the stone will make adhesion more difficult. If you can hang a holder from the bottom near the edge you can choose something with a larger base to allow a larger contact area for gluing. You'd also be gluing to the rough, unsealed bottom of the stab where the bond would be stronger.
