Advice On Replacing Bathroom Vanity
Hi,
I recently purchased a house, and the master bathroom vanity is just falling apart, it's about 20 years old so that's understandable.
Anyway, the current vanity is 60" wide, 18" deep; however the new vanity I'm considering buying is 60" wide and 22" deep. The bathroom tile goes right up to the current vanity.
Does this mean if I want to use a larger vanity that I need to replace the entire floor? Can I just cut the existing tile so it is flush to the new vanity?
Sorry if this is elementary question, I'm new to bathroom remodeling.
Temporarily Suspended
You can remove the current vanity & add tile or shim the section that doesn't have tile or cut the tile as you suggested. No matter what, you don't have to replace the entire floor.
I would add plywood to make the floor behind the tile of the same height and then set the new vanity on that - it will sit on top of the tile that way. This is Pulpo's suggestion about shimming the floor.
