Vinyl sheet flooring in shower
Hi everyone. I have been mulling over using vinyl sheet flooring for my 3 shower walls since it has come a long way in being better plus it has so many patterns to choose from. Has anyone done this? and, if so, what prep is needed and the VERY best adhesive to use? Thank you.
Stop trying to be lazy, you don't put that in showers. The first time you subject it to heat, the adhesives will soften and it will fall off the walls. If you want to go cheap, look into some of the prefab panels that you glue up to the walls. Use shower surround adhesive and have at it. It will be a much better cheap option for you.
