crack in fiberglass tub
3 month in the newly built house, we find 2 hairline cracks at the foot-end of the fiberglass "garden tub". one is about 1" the other is about 4", on the rounded part of the floor, on the side. I don't have a problem fixing it, but should I be concerned that there's improper support underneath? Are cracks this early normal or not? and is there any way to tell if it's superficial or goes through? The tub is tiled in and on the 2nd floor, so there's no way to get at it from underneath.
Received 1 Upvote
1 Post
Do you have a "new home" warranty?
You shouldn't be having hairline cracks in a new tub. Check with your builder.
As for repairing it, if you don't have a warranty, you can use appliance touchup liquid to seal the hairline cracks.
It comes in a small bottle with a cap brush similar to nail polish. It primarily is used to touchup white enamel appliance chips, and dries very hard.
Make sure that the cracks are clean and dry (I use a hairdryer for this), brush on a coat over the crack, and allow to dry overnight.
Clean up the edges with a Q-tip and acetone (nail polish remover) while still wet from the application. Use two coats, if necessary.
Good Luck!
Mike
Good Luck!
Mike
