Adding a bar height countertop to kitchen island
I currently have a kitchen island that is at regular counter height. I would like to add an L-shaped bar height countertop around the outside of the existing island. I am looking to frame the walls for the L-shaped. Then to finish we'll add door panels and corbels to support the countertop. Should I frame the L wall using 2 x 4 or 2 x 6 lumber? I'm leaning toward 2x6 to give the wall more depth but looking for opinions.
I would think 2x4 is more than sufficient but how it looks is entirely up to you so go 2x6 if you want.
This totally depends on weight of counter material and your desired overhang.
For example, if you use granite and want a 10" overhang, provisions will need to be made for that. You need serious corbels or rods laid down.
What is the intended width of the stone on the overhang? What are the overall dimensions of the island and the "L" extension you are adding. What is the step up from normal counter height for the bar area. What will be the overhang on the island side of the bar?
The current island is 24" x 63" and is 34 1/2" high. The height of the L shaped counter will be 40 1/2" plus the 1 1/2 " countertop. The L wilbsimply go on the outside of the island and were looking to have a countertop that can be used for casual dining. We're not sure of exact width but I'm thinking 18" wide with a 1 1/2" overhand on the island side and 12" overhang on the outside.
