Replacement for cracked decorative panel on tub skirt?
Hi all,
I have a tub that is perfectly fine except for a cracked decorative panel on the tub skirt. I believe the skirt is this model from American Standard:
[ATTACH=CONFIG]49033[/ATTACH]
As you can see it has 2 small decorative rectangular plastic panels on the front. In my case one of them is cracked right down the middle (my cat decided to try and pry it loose one day - don't ask lol). I did try superglueing it but it is jagged and looks terrible. I'd like to just replace the cracked panel.
Is there any way to get just a replacement for a single panel, without buying/installing a whole new tub skirt? I'm fairly sure I could just rip the
cracked one off and use velcro or 3m tape etc. to hold the new panel in place... but I can't find anywhere that sells these panels, only the entire skirt assembly (which is almost $200).
Temporarily Suspended
http://www.tubz.com/images/Tub/front...nel-access.jpg
That might be what you want but it's only worth it if you get rid of the cat.
