Gluing (or otherwise attaching) laminate backsplash to laminate countertop.
Long story short: I bought a countertop for my bathroom vanity but it was the depth of a kitchen counter. I cut the back part off to make it fit. I now want to use the 4 inch backsplash thing (I dont know what the correct terminology is) by cutting it straight, attaching it to the back of the counter, and then putting a bead of silicone in the corner.
The counter is already attached to the vanity, so screwing it from underneath would be very hard.
Can I attach it to the other counter and wall using a bead of silicone, in the same fashion as underneath a sink, or should I use PL, contact cement, or whatever else I need to use?
P.S. I already know they make counters for bathroom vanities, but I had already cut the width of it when I realized my mistake so I couldn't return it.
Thanks!
Thanks!
You don't need a very strong adhesive on the back and side splashes. I generally use a kitchen and bath adhesive caulk. Run a zig zag bead across the back of the splash and also run a continuous bead along the sink top and set the splash down into it. It will help prevent water from seeping underneath. You can do what ever bead you want along the inside corner that is visible.
PS- am I allowed to comment on this?
I would recommend using 100% silicone caulk to attach counter to cabinet and splash to walls.
The adhesive caulk gets very hard with age and removing the top (or a sink) is very hard to do without damage.
The silicone remains flexible and can be cut
Yes, just wait. No need to slide.
The counter will settle in and cure. If the walls don't want to grab or sit crooked, you can use hot melt glue for instant grab until silicone dries. Just a few dabs of hot melt will hold it and allow you to position the piece.
