Installing Shower Wall Surround Over Tiled Base
I thought this was a fairly straightforward question, but can't seem to find an answer online and haven't ventured to THD yet. I'm redoing a basement bathroom. The bathroom has a poured concrete shower base that I'm tiling. I have no interest in tiling the walls as well, but I can't seem to find confirmation on whether shower wall panels (like you would buy at big box) can be installed above the tile floor.
Thoughts? Is this crazy talk?
Temporarily Suspended
Why not install a shower base & forget about the tiles completely. If you still want to go with your original plan, make sure that you create a lip so the bottom of the panels cover it.
Luke, welcome to the forums.
Many times it helps to add pictures to get us on the same page as you faster.
http://www.doityourself.com/forum/el...your-post.html
That out of the way, there is a lot more to building a waterproof shower than a hole in a concrete floor, tile and some walls. You basically need to build a large cup with only one outlet which is the drain. Cement, tile and grout are not waterproof, so your initial premise of tile over concrete is not a water tight solution. Custom showers consist of multi-layers of concrete, waterproofing membranes, more concrete and then tile - all leading to a specially designed drain that allows water that got past the first layer of concrete and mortar/grout to still be channeled to the drain.
This membrane is then taken 10 or so inches up the walls. The walls then have a shingled membrane that overlaps the base membrane partially up the walls to further ensure that all moisture stays to the inside of the shower and does not leak out.
