Installing a curved shower bar
Trying to install one of these curved shower bar.
In my case I do not have a walk in shower, but a tub. So it needs to be a specific height off the floor so the shower liner would not be too low or too high. It also has to be a specific distance horizontally from the opposite wall...which means the two ends need to be mounted at a fairly specific location on the wall.
Problem is I do not have studs at that location. I have wall tiles but that goes to about 72" off the floor, so the shower arm would be mounted on the sheet rock above that. I don't feel secure using just drywall toggle bolts or plastic anchors.
Any idea how I can mount it securely?
I would use toggle bolts and add a dot of construction adhesive behind the plate to help glue it to the drywall. Be sure you get the rod level so the curtain doesn't dip lower at the center. Better for the curtain to be a bit high than too low. If too low it can get pulled down by stepping on it.
To add to X's comment, also invest in some really good rollers not the cheap hooks. As in the picture, those utilize little bearings that help the curtain move smoothly. That is where all the force is placed on the bar. The cheap dept store hooks never work and will put undo force on the bar as you try to slide the curtain.
Here is a link to a very strong anchor. You will need to purchase the special drill bit also.
To use these, Ideally your mounting plate will have only one center hole.
WingIts World's Strongest Fastener Standard (2-Anchors)-RC-MAW35-2 - The Home Depot
I've used these to mount free-hanging vent hoods and they are not kidding when they say the anchors are strong.
