Waterproofing between shower pan and floor
Hi all,
The attached image shows the newly laid shower base.
I had to chisel some mudjob away to be able to fit in the new base.
As you can see, there is about a half inch gap between the shower base and the floor now. The edge of the floor is taped up to prevent crumbles from falling into the work area when we were positioning the base.
Should I do something to waterproof this gap? It's about an inch deep and then the plywood is exposed. It is possible that over time, some amount of water can drip into the location where the floor meets the base.
Can I spray some "Great Stuff" into the gap ?
Thanks
Tbone
Thanks
Tbone
You can caulk or even fill with thinset or whatever portland product you have around. The floor will not be waterproof or is it supposed to be. To make it waterproof would require a couple more steps which is not usually done for bathroom floors. Caulk for sure to fill the grout space after the tiles are set.
Jaz
Jaz
