Removing bathroom wall tile
Old 11-22-15, 05:25 PM
I have an old mud wall behind the tile an inch and a half thick it is on a one x two on two of the walls but the wall behind the tub they applied it directly to the cinder block what is the best way to remove it
Old 11-22-15, 05:49 PM
czizzi's Avatar
Received 9 Votes on 7 Posts
Demo hammer and a tile bit. The wall mud will be much more brittle than the wall block and should chip off.
Old 11-22-15, 06:45 PM
I've been trying air hammer with chisel bit is th at ghe same thing. If not whats a tile bit
Old 11-23-15, 03:38 AM
czizzi's Avatar
whats a tile bit
A chisel bit for a demo hammer that is flat and also ground to a point to get under tile and pop them off the wall or floor. Go after the cement wall in strips. Cut a series of 2" channels and then return and run down the strip and take it off a little at a time. Don't go after huge chunks, you need to break it up into smaller pieces first (or strips).
Bosch SDS Max Tile Chisel-HS1915 - The Home Depot
