Resurface/Replace Formica Kitchen Countertops
Our Kitchen countertops are 1 piece formica....i.e. surface, backsplash, and edging are 1 piece. We've decided to redo just the counters. I've read that you can just do an overlay but I wonder if this is feasible with my current 1 piece set-up. Or should I remove the entire top including the mdf (?) that the formica is attached to and install new mdf and add the formica or just buy a pre-built top?
I've got the tools and like doing DIY.
Yes, you will need to remove the old countertop completely and make new ones... or order new ones if you want a no drip edge or a preformed backsplash.
Laminating new tops is more labor intensive than you might think, and requires very good finish carpentry skills. So if you like a challenge and you're very confident in your abilities, you can make laminate tops and a separate backsplash... otherwise I would suggest you buy preformed and assemble it yourself... which still requires a measure of skill, just not as intensive.
Check out a newer far better looking one piece counter that Home Depot is selling.
It has a Roman Ogee edge instead of the dated rounded edges and looks like a stone top.
There is no way to over lay the ones you have.
