Blocking for Mortar Shower Pan
Old 02-16-16, 06:28 AM
E
Hi, This site is proving to be very helpful for me. When adding blocking for the shower pan box I have the water supply lines in the way and I’m not able to add the block between the studs in this area in which to add the mortar. What would you recommend that I do in this case? Thanks
Here is a photo
https://dl.dropboxusercontent.com/u/...160216_002.jpg
Old 02-16-16, 06:55 AM
XSleeper's Avatar
Received 1,644 Upvotes on 1,472 Posts
I used 3/4" plywood and attached it with kreg pocket screws. You could also notch your blocking.
