bath tub leaks - drain and overflow
Both the bath tub drain and overflow leak from the underside of the tub. I tried to fix this about 6 months ago and they are leaking again. Does anyone have any suggestions on how to make a better seal in these areas? I tried tightening the drain cap and the overflow cover but it does not help. I have easy access to the underside of the tub but don't want to make fixing these leaks a regular habit.
Thanks
chris
Thanks
chris
Received 1 Upvote
1 Post
Is it leaking at a threaded connection?
If so, smear a little clear silicone caulk on the threads.
If it's leaking from under the drain flange, replace the plumber's putty under the lip of the drain.
Good Luck!
Mike
Good Luck!
Mike
