Acrylic shower walls
Old 02-12-17, 10:11 AM
kennyv519's Avatar
I need to glue shower walls to cement backer board. The manufacturer recommends Liquid Nails N715 or N915. I used this adhesive on a friends walls recently and the adhesive did not stick and the walls were laying on the ground the next morning.
What other adhesive could be used that will A) not burn through the acrylic and B) stick to the cement board?
Loctitie Tub Surround states it cannot be used on cement board. Would a FRP glue work?
Old 02-12-17, 10:29 AM
Received 3,493 Upvotes on 3,136 Posts
I'm not a pro carpenter. I have done my own work and I've had problems with Liquid Nails in the past. I think in your case it may be the porous walls.
I've used this before for similar jobs and it has worked fantastically.
You can get it at lowes and depot.
Power Grab Ultimate Construction Adhesive
Old 02-12-17, 10:30 AM
kennyv519's Avatar
PJmax, can't use that as it will burn through the acrylic as it's a heavy petroleum type adhesive. This is the problem I'm faced with, findind something that will stick to hardi board and NOT burn through the acrylic.
Thank you!
Old 02-12-17, 10:44 AM
Received 759 Upvotes on 664 Posts
I wonder if you sealed the wonder board with paint if that would allow the liquid nail to work ??
