Doorway opening size
Hello, I am opening up the doorway in the photos below. Original door way was 30", I would like to open up to 48" to matchup the left side with the walk through in the foreground. What are people's thoughts on a 48" opening? Too big?
https://goo.gl/photos/hA1AoYQMFZYVbdtT6
https://goo.gl/photos/nKrRJttgo9UmQeCeA
Heres a before of the whole space:
https://goo.gl/photos/TNmntrnPqDgdC5zF8
and some during photos:
https://goo.gl/photos/pKvsuG2sAntNERxU6
https://goo.gl/photos/roSZhRNEUtcXUPDM7
as it sits now:
as it sits now:
I think that makes sense. Having to jog around that little wall would be annoying. I assuming this is just an opening and there won't be a door (well, doors)....
But it looks like that header over the doorway might be a beam; it's way bigger than would be needed for a typical header. Is it carrying the load of a wall on the level above, or ceiling joists? If so it will be a bigger job as you can't just extend a beam.
Correct, just an opening with no door. The header over the door way is not a beam, and Ive check end its not carrying the load of the wall above.
I am not sure as to why they used such a header in that opening.
I think it would look fine either way. I like opening up kitchens as much as possible.
Is the ceiling finish (texture) the same on both sides? If not, and you don't plan to redo, then having a transition would look better. But it wouldn't have to be as big as it is now; even a few inch bump would provide visual separation and might make for less ceiling repair.
Will the flooring be the same in the kitchen and hallway? If so I would definitely open it up. If there will be different flooring you could still go either way.
