Raising a Bathroom Vanity
Old 04-16-18, 05:45 PM
D
Hello and thank you in advance for any replies. I知 raising my bathroom vanity from 30 to 36 inches. The issue that I知 having is encroaching on the mirror as it currently runs the length of the wall and is flush on the vanity backsplash to about an inch under the light fixture.
My question is- can I raise the vanity and let it be flush against the mirror? Do I HAVE to move the mirror?
Old 04-16-18, 05:47 PM
XSleeper's Avatar
Received 1,947 Upvotes on 1,747 Posts
It's your house, you can do what you want. But IMO, yes, you should remove the mirror.
Old 04-16-18, 05:49 PM
Norm201's Avatar
Received 727 Upvotes on 643 Posts
There is no reason why the mirror can't be touching or even resting on the back splash. Only problem I see is that it will get dirty faster. If you want to move the mirror we will need to know how it's attached to the wall. If it's glued to t he wall then I would not recommend trying to move it. If it's held on with typical mirror clips then moving it is very possible.
