HardyBoard or Durock Cement board to Concrete Wall
The long side of my tub has a concrete wall.
The top depth is 1 1/2", and the bottom will fit a 1/2" thick board on the tub top-lip.
Can I shim up the top with two pieces of board with strips glued together to 1" to then glue or screw one whole piece onto the wall?
Can I use liquid nails or mortor/Thinset?
I used 1/2" wood strips 24 years ago to nail to.
( I then am going to coat everything with Redgard or Aqua Defense.)
-- Rick
-- Rick
You could probably use a few Tapcon screws and liquid nails to secure the wood back to the cement blocking. I don’t see anything wrong with doubling up two pieces as long as they are well secured.
