Marble pencil trim next to medicine cabinet - doesn't look right . . . ?
When you open the medicine cabinet, you see this edge of marble pencil. It's rather sharp, and I think it looks clumsy and unfinished. What should be done here? Many thanks for advice and suggestions.
I guess it's a matter of personal taste. They are there as a finishing edge. I see nothing wrong with it. About the only thing you can do is remove it and put on something else. A standard bull nose can be used but you'll need to cut around the outlets.
Or are you referring to the rounded edge as it meets the medicine cabinet edge? I think I might carefully try to file that edge off to a square or straight edge. But really, it's not that big a deal. The only time it's seen is when you open the cabinet.
