Undermount sink, best mounting method?
Old 05-16-19, 09:47 AM
R
Question Undermount sink, best mounting method?
I am going to be installing an under-mount sink using butcherblock countertops. I see lots of options from rails to brackets and clips. What is the best method?
Sink is here
https://www.homedepot.com/p/VIGO-All...5217/204441790
Was looking at these clips
https://www.amazon.com/Undermount-Si...gateway&sr=8-4
Old 05-16-19, 04:39 PM
Received 4,047 Upvotes on 3,631 Posts
According to the installation guide..... that sink comes with the mounting clips. They should be ok.
Vigo install guide (pdf)
Old 05-17-19, 07:32 AM
R
Interesting, I purchased it open box and I don't recall seeing them but I may have missed it. I'll give it a second look. If they're not there maybe the company will supply replacements. Thanks for that info!
Old 05-30-19, 03:28 PM
R
Question
Hey PJ.
I was about to mount the sink but the mounts have these little bolt inserts. Because I am using butcherblock, would it be better if I just get some screws and pass on the inserts?
Old 05-30-19, 04:01 PM
I would. Those inserts look to be for a masonry type countertop .
When buying hardware be very conscience of the thickness of the counter.
You don't want any sharp points poking thru the top.
Old 05-30-19, 04:57 PM
R
Right, that was my thoughts too.
The butcher block is 1.5" Should I get 1 1/4 screws? Any specific type of screw I should get??
Old 05-31-19, 01:39 PM
R
Would I use lag screws or construction screws??
