Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Designing Kitchens and Bathrooms
Reload this Page >
easy to re-caulk quartz countertop seams/sink seam?
Old 07-04-19, 09:49 AM
C
Received 1 Vote on 1 Post
Our kitchen is now ~2 years old and the caulk in the quartz countertop joints behind the sink, and a small section between the sink top and counter are deteriorating (see pics). Is it safe to just clean out all the caulk within the deteriorating areas and smear in some new? I'm not sure what type is in there now, but I am guessing silicone? Should the caulk at the back splash seam be the same type as between the top of sink and counter?
fyi- the chunk that is ripped out between sink/counter I did by accident when trying to scrub a stain out of it too hard..
Old 07-04-19, 11:05 AM
Marq1's Avatar
Received 535 Votes on 495 Posts
Yes, or can use siliconized latex with micro-ban!
Old 07-04-19, 11:11 AM
Received 1,608 Votes on 1,480 Posts
Peel out anything that is loose and replace it. A plastic edged tool makes removal easier.
Old 07-04-19, 12:15 PM
P
Received 966 Votes on 887 Posts
Before caulking put some rubbing alcohol on a rag and shove it in the crack to help remove any soap scum and dirt.
Whichever caulk you choose I recommend using a solvent based instead of water based.
Esther Allen voted this post useful.
Old 07-04-19, 01:01 PM
XSleeper's Avatar
Received 991 Votes on 902 Posts
If you use rubbing alcohol you will need to wait until it is TOTALLY dry before you caulk because silicone is repelled from anything wet with rubbing alcohol, and it will affect the adhesion otherwise.
I would recommend a high quality silicone, not the stuff on sale at the big box store. Dow Corning 795 would be an example.
Old 07-04-19, 01:28 PM
C
Thanks for the replies! Sounds like complete and clean removal / dry / and good silicone based caulk is the plan.
Old 07-28-19, 10:04 PM
C
Done and done.
Thanks again for the tips!
