Update needed
Update needed
Hey all. I am in the midst of renovating the downstairs of a mother daughter home. This kitchen and living space has not been used in years. Any thoughts on how to update it? The floors are being redone next week. See pictures. I’m on a super tight budget. Wondering if anyone has dealt with these kind of tile countertops or the brick.
Last edited by PJmax; 09-10-19 at 12:30 AM. Reason: reoriented/enlarged pictures/added flooring pic
Welcome to the forums!
Are those solid bricks or just thin brick 'tile' adhered to drywall? they can be painted. I think removing or painting then would make the most difference. A new countertop would be nice but it depends on how tight your budget is.
It’s like real brick feeling. Sorry I am no expert. I was thinking of painting them. I don’t hate them just more like I hate how dark it is in there. Is there a cheaper way to handle the countertop. The tiles are in good condition. Can I put something over it? Might be worth waiting I guess. I have to recover from the flooring.
Funny how pictures can make things look better than they might actually be. From the pics that kitchen looks good. But I agree it is dark and needs to "opened" up a bit. A new floor in a light color will help. I hate to see brick work painted, but in this case it would help. That cupboard door below the sing looks like it's in bad shape. I think the door pattern is common enough that you should be able to get a replacement.
My opinion, if you plan on staying there then do the minimum a suggested above, then later when finances get better plan on a complete remodel. One idea is strip the brick and go with painted walls. Even that small thickness of the brick being removed will open up the look of the room.
Here are some instructions if you decide to paint the cabinets - The Ideal Cabinet Repaint the 2 most important things is making sure they are clean and using the proper primer.
I don't like how the hardware is in the middle of the doors. Painting the cabinets would make a big difference and new hardware. Don't know what's involved in plugging up those holes, getting new hardware, and placing them somewhere else.
Also painting the brick would make a big difference. I've seen people do this and it really brightens things up.
Then the countertops may not look too bad and you can always change that down the road.
I also think the paneling, wallpaper and drop ceiling are pretty dated. When we bought our house (a lot of years back), we had the same stuff in our kitchen. Eventually, we tore it all off and put up drywall. If you can't do that yet, I'd at least paint that paneling and wallpaper, too. The kitchen looked a lot bigger when that drop ceiling came down too.
We had that “Z” brick in our kitchen. Actually came off pretty easily, but the sheet rock needed to be repaired, patched after. Take it off, you will be glad you did.
Normally you can get a chisel or stiff putty knife behind the brick 'tile' and pry it off. Once you get started it generally gets easier. Once the tiles are removed you'd need to scrape off any remaining thinset/mastic, apply Gardz to any exposed gypsum and patch the drywall as needed.
