Caulking around newly install bathroom vanity
Old 03-25-20, 05:45 PM
I just had a a bathroom remodel but the vanity is not caulked around the wall. Should I caulk this area? One side does face the shower but there will be a glass partition installed to prevent water.
Old 03-25-20, 05:54 PM
XSleeper's Avatar
Received 338 Votes on 310 Posts
It really depends. Once caulked, it becomes a maintenance issue. If the gap is crooked, it sometimes looks better caulked. But you usually want to use a paintable caulk since the wall will need to be repainted someday.
Old 03-26-20, 12:53 AM
Marq1's Avatar
Received 192 Votes on 179 Posts
If the vanity sits flush and there are no gaps or rough edges then maybe you don't need to. If your concerned about water getting behind then it depends if you have a backsplash or how messy the uses are.
Always the issue with caulk, once you start your kind of hooked and have to always maintain!
Old 03-26-20, 10:20 AM
Thank you for the replies. I am only caulking around the left side since it faces the shower.
so I have another question. Where can I find a 3x60 backsplash for the top of the vanity?.
Old 03-26-20, 11:39 AM
Marq1's Avatar
Where did the vanity come from, thats typ where the back spash is obtained. If not a granite shop can make one but will it match the counter top?
Old 03-26-20, 04:05 PM
I bought from a bathtrends in Miami Florida. I didn’t know I’d need the backsplash.
ill try a few local shops to see if I can source it.
Old 03-26-20, 06:55 PM
lawrosa's Avatar
Super Moderator
Received 45 Votes on 40 Posts
I only use phenoseal.. past 35 years...
https://www.homedepot.com/p/Phenosea...0522/100357228
