Prefab shower pan membrane?
Old 07-26-20, 06:31 PM
Q
Received 1 Vote on 1 Post
I'm installing a Schluter 40x60 shower pan
i understand that all the corners and drain need to be waterproofed with thinset and membrane but it's not clear if the entire pan needs a rectangular piece of 48x60 on it as well?
I assumed it wasn't necessary since you don't on the vertical kerdi board on the walls
Old 07-26-20, 06:49 PM
XSleeper's Avatar
Received 721 Votes on 667 Posts
Have you watched all their youtube installation videos? That would be a good starting point.
Old 07-26-20, 07:59 PM
Q
Yes, but wasn't clear since sometimes they do sometimes they don't. It seems like if you use the kerdi pan then you only waterproof the edges and floor/wall points
Old 07-27-20, 05:12 AM
Marq1's Avatar
Received 396 Votes on 370 Posts
When I did my Prova system the pan was not covered so it required membrane, I thought the Ditra systems had membrane pre installed (Pink fabric) and all you needed was to install around the edges.
But, you need to confirm with your material!
