Need to set kitchen upper cabinets away from the rear wall
Hello Everyone,
I am in the process of renovating our kitchen, starting with new cabinets. Part of it is removal of the soffits and taller cabinets to reach the ceiling. In order to clear the reason for one of the soffits, I need to float the cabinets on one wall out about 2 1/2" from the rear cabinet wall. I will have a 1 5/8" divider on one end separating the fridge space from this set of cabinets and the other side is a corner with a 24" corner cabinet going in. The cabinet between the corner cabinet and the divider wall is a 30" short cabinet that will also hold a microwave.
My question is, if I run some 2x6's mounted to the studs near the top and bottom of the cabinet (leaving enough space on the bottom to add a matching filler board) and mount the cabinets to those, should I need to worry about them holding up well? I will have the corner cabinet into the 2x6's on one side and into the studs on the other. I also plan on attaching the two cabinets through the face to each other and the microwave-holding cabinet into the divider wall. The microwave is deep enough that it will be attached at the rear wall and to the cabinet above it. Thanks in advance for any insight.
If you put them horizontally, I would stack two 2x4s and lay them on the flat, putting pairs of fasteners into the existing studs . For your 3" side, that would be 2 pieces of 2x4 stacked. On the 2 1/2" side, either rip the 2nd piece down to 1" on a table saw or use 2 rips of 1/2" plywood to equal 2 1/2" Be sure you position the height on the wall correctly so that they are level and so you can easily hit them when you go to screw the cabinets to the wall.
You will want to check the corners for square. If anything is out of square, that will affect the width of your filler to the right of the fridge. So you might want to save that for last, after the other cabinets are installed, and actually measure what you have left to work with. That 3" filler might also need to be scribed to the wall if it's not perfectly straight or plumb.
I agree two horizontal 2x4s well secured would work well.
Another option would be to build a stud wall with 2x4 or 2x3s on the 2" width. This would allow the weight of the cabinets and microwave to be well-supported and a solid wall to have a backsplash mounted to.
First a before picture: [url]https://imgur.com/a/aGHbV9G[/url]
The house has drop drywall ceilings, we figured this out when installing recessed cans. Before starting kitchen renovation and cabinet design, I cut a large access hole into the ceiling to measure the height, measured 108", and had custom cabinets that will go up to 102" with crown taking it to the full ceiling height.
Well we demo'd and look at this [url]https://i.imgur.com/owE5AV8.jpg[/url] I guess you never know what you find in these old homes. The roof line intersects the ceiling and the lowest point not at the sink/window is now 99". The same thing is in the master bedroom that mirrors this room.
Well what do I do now?
1.Go with it. Drywall the curve and try to modify the two upper cabinets on this wall. If I can't get them to work, order two new wall cabinets that will work at 99". This might be the cheapest solution, but I think the ceiling is awkward and not attractive looking.
2. Drop the ceiling to 99" and have two new upper cabinets and the 1 fridge and 1 pantry cabinet built. This is probably $3k in a $30k renovation, so not the end of the world, but will definitely hurt.
Looking for other ideas on how to solve it. Here is the cabinet layout: [url]https://imgur.com/a/Cq2gJmO[/url]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/932x622/pic1_07a1e4a0580d6d94bae95b888647d45fef401305.jpeg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/897x673/pic2_fecb79e0404c2ad0c67ab8eb4025d4a7b82046e6.jpeg[/img]
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/863x666/pic3_e37a8dd67c8ff9896abd80f33a6d9bc4342e5f5b.jpg[/img]Read More
Hello all. We are looking at trying to replace the Russell stovetop that was in our house when we moved in. The grates are cracked (can't seem to find replacements), one ignitor doesn't work (can't find a new one), and in general we're slowing moving our house to more electric. So we'd prefer to go induction if at all possible.
Can anyone recommend a way to replace this guy? If it was just a drop in, it'd be no problem, but unfortunately it is old enough (probably from the 90's just before russell went out of business) that has quite the front profile). We've tossed around the idea of redoing the whole kitchen, but there are more pressing needs in the house at the moment so we're looking to just replace the stove top.
Any suggesting would be greatly appreciated!
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1342/stove_18354bb7999ef31436113ff61bf83a237ea17cef.jpeg[/img]
Read More
