Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Designing Kitchens and Bathrooms
Reload this Page >
DIY Floating Vanity with 12" solid surface front/apron
Old 03-19-22, 12:19 PM
A
Greetings! I would like to install an 84" wide floating double sink vanity, quartz top with 12" front depth apron across the front. The left side would have a knee hole for make-up area and the rest to the right end would have a wooden shelf for storage. I've seen how floating vanities are supported with brackets in studs, etc.. I was wondering how to support the large front apron. I don't mind having a light ash/hickory open base/shelf for support as it would match my new floor tile. Any suggestions on building an attractive open base with shelf for support? I've attached a very rough sketch. I believe I can have the top manufactured locally and I have a very good carpenter/jack of all trades that can build the base, install vanity and attach plumbing.
Thanks for any suggestions.
File Type: pdf
Old 03-19-22, 04:32 PM
Received 3,609 Upvotes on 3,235 Posts
Many people won't open a pdf file.
I added a diagram from your link but even enhanced it's not too clear.
Old 03-20-22, 01:23 PM
A
Thanks, PJmax
Thanks...I'm still new to this...is there a preferred type of attachment? thanks again!
Old 03-20-22, 01:59 PM
No problem. You can post pictures directly to the board...... How to insert pictures.
