Vanity/Wall Gap
Old 04-01-22, 03:59 PM
Received 1 Upvote on 1 Post
Vanity/Wall Gap
Hi. Any suggestions to solve this gap between the wall and vanity counter top? The vanity came with a backsplash, which I didn't want to use. Thinking I may have to get a separate 3" backsplash and create a side splash with it, although I hate that look, which is why I tiled to the countertop in the first place. gap seems to big to caulk, it's 1/4 inch at it's largest and tapers down to flush with the wall
. Any good ideas? Thanks.
Old 04-01-22, 06:41 PM
XSleeper's Avatar
Received 1,808 Upvotes on 1,626 Posts
Scribe it to the wall. If your biggest gap is 1/4", take a 1/4" shim and your pencil and slide the shim and pencil together along the wall at the same time. That traces the shape of the wall onto the countertop. Then take the countertop off and trim it. When you put it back on, it will fit tight enough to use a very small bead of caulk. Kwikseal Plus would be a good choice.
