Shower curtain rod finial removal
Old 05-22-22, 11:07 AM
Received 1 Upvote on 1 Post
I have a shower curtain rod that is rusting (stainless steel my a**), I installed it several years ago if I remember right with screw-in brackets that the finials snapped over. But for the life of me I can't figure out how to get the finals or the rod off. The rod doesn't seem spring-loaded. Don't really want to pry the finials out because it will damage the drywall.
Any ideas or experience with these? Should the finials just slide back on the rod?.
Old 05-22-22, 12:52 PM
badeyeben's Avatar
Received 54 Upvotes on 48 Posts
Maybe a few pictures of the problem rod ends would be helpful. Close up and entire shower pictures so the experts can see what you see. There are too many kinds of shower rods to be able to answer without a picture.
Old 05-23-22, 05:01 AM
P
Received 1,844 Upvotes on 1,651 Posts
Your rod may twist to extend or retract. Turning the two halves should tell. Then the things on the wall can be nailed, screwed or held in place with adhesive tape though sometimes they are just held in place by the rod's tension.
Old 05-23-22, 06:49 AM
Received 266 Upvotes on 238 Posts
If your memory is correct look for a small cutout along the edge of the finial/cover.
This is where you insert a screwdriver and twist to remove it.
If the wall has been painted since the finial has been installed cut around it with a knife so you do not pull up paint when removing it.
get a thin piece of metal if you need to pry onto the drywall.
Try using a putty knife.
Old 05-24-22, 10:07 AM
I'll look for a cutout tonight. Will send photos if it's not there!
Old 06-03-22, 06:17 PM
Problem solved but I though you'd like to hear the story. The finials finally came off with a twist, no prying involved. The finials just slid back on the rod once they were released. The rod simply slides to length (no threads or springs), with a slot that fits over a little hook in the nylon-plastic hanger (see photo) to hold it in place. Kind of clever, but not intuitive!
Thanks for your help.
Old 06-03-22, 06:23 PM
To follow up, frankly I can't understand the prevalence (say, on Amazon) of the spring-pressure type of mount, which inevitably fall down and end up damaging the wall. I would like to replace this rod with another of the same type that fits over a screw-in mount.
Of course the ideal would be to replace only the finials. The rod itself has not rusted as you can see.
Don't know if this is a standard mounting arrangement and I don't have the brand. Does anyone know if it would make sense to try to find replacement finials? Or at least a complete rod with finials that could use the same wall mount plates?
Old 06-04-22, 03:35 AM
I do not know where to get replacements but if you cannot find any then I would sand them down and just paint them white.
Old 06-04-22, 01:00 PM
Interesting idea - or black.
Thanks,
Old 06-04-22, 01:24 PM
Received 3,485 Upvotes on 3,128 Posts
That's not really a finial.... it's more of an escutcheon or pipe rosette. They are available in the home improvement stores as pipe escutcheons. They cover the hole in the wall. They come in different finishes and sizes.
Chrome escutcheons at the depot
Rosettes
Old 06-04-22, 02:50 PM
Thanks! They seem to be designed more for raw plumbing than fixtures, but might do the trick. Not finding any though in a metal that won't rust.
Old 06-04-22, 02:54 PM
I may just go with a spring-loaded rod with a wall bracket to support it like this.
https://smile.amazon.com/Curtain-Adh...09XX7C8K7&th=1
Why are the simplest things the most complicated? In a perfect world there would be a standard mounting bracket . . .
