Looking for a two piece range hood vent ...
Old 07-28-22, 07:24 AM
R
Question Looking for a two piece range hood vent ...
Looking for a two piece range hood vent with a flange that I can properly flash with the tyvek under the vinyl siding. It seems all the vents I see are placed on top of the siding and Caulked. Unless there is a reason they dont seem to make them this way...
Old 07-28-22, 08:21 AM
P
Received 1,953 Upvotes on 1,749 Posts
Try looking for a standard vent, don't look for a vinyl siding vent. You can use a standard vent and mount through trim stock then trim around it with J channel.
rufunky voted this post useful.
Old 07-28-22, 10:04 AM
R
By trim stock are you refering to something like a PVC mounting block?
Old 07-28-22, 10:40 AM
P
You can use a mounting block if you want. Trim stock is the aluminum sheet material, formed to shape as needed and used to trim around a window and fascia. You can also cut a piece of the material and put on the wall sort of like flashing. Run the vent through the middle, then trim a picture frame with J channel for the vinyl siding to go around it.
Old 07-29-22, 07:52 AM
R
Got it! thanks Pilot
