Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Designing Kitchens and Bathrooms
Reload this Page >
Kitchen backsplash, remove window sill bottom or not?
Old 02-14-23, 06:56 AM
B
Received 3 Upvotes on 3 Posts
I am planning out kitchen backsplash tile install. Does the bottom piece of the window sill gets removed permanently. or tile around it, or remove, tile then reinstall it?
Old 02-14-23, 07:03 AM
P
Received 1,840 Upvotes on 1,647 Posts
The window trim is usually left in place. You can't nail wood trim to tile.
Old 02-14-23, 10:58 AM
2
Received 336 Upvotes on 288 Posts
Or not...
Tile installed under window stool with no apron.
This picture also illustrates an adjustment to avoid a thin sliver of tile at the vertical trim. Full tiles in the rows below the window were trimmed short to shift the pattern 1/4 inch to the right. Tiles were being installed from right-to-left. A full tile would have extended 1/4 inch past the vertical trim and would have required a 1/4 inch sliver at each next full tile to the left of the trim.
Old 02-19-23, 07:49 AM
2
Window trim can also be installed over tile. Here is an example in a bathroom where the stool is deep enough to accommodate the thickness of the apron and the tile below. The apron is glued to the tile.
Old 02-19-23, 07:51 AM
2
