Coming up 1/4" short with shower tile at the ceiling..
I'm trying to lay out my 4x12 subway tile from the shower base to the ceiling. After laying them on the floor with the 1/8" spacers I end up a 1/4" short at the ceiling, my measurement from the base to the ceiling is 93 1/2 inches. I know the standard height between your bottom tile and shower base should be 1/8", if I was to raise the bottom tile up and leave a 1/4" gap, that would gave me a 1/8" caulk gap at my ceiling. Only problem is I'm bringing my tile out pass my shower base 2 inches and putting in a small piece from the bottom tile to the floor, am I'm going to show a 1/4" grout line from my bottom tile to the floor? Any ideas?
I was thinking about doing that, I was just worried I may get a few rows off wider than the other ones, then hope I can get he other side to match. I was just looking at it again and if I moved the bottom tile up an extra 1/8" I wouldn't have a problem keeping all my grout lines at a 1/8" even passed my shower base. I would only have a 1/4" bottom tile gap that I would have to caulk to the end of the base, then around and down to the floor. I was just wondering if a 1/4" is too wide to have on the bottom tile to the base?
You could install molding around the top to conceal any gap. Leaving extra space at the top also allows you extra fudge room if your grout spacing gets a little wide.
If you want to space out your grout lines to run tile right to the ceiling I would measure both sides of the wall and pop horizontal chalk lines periodically. You can use the chalk lines to make sure your tile stays at the right height to end up perfect at the ceiling. I mentioned "both sides of the wall" because it's common for a wall to be slightly different height at each end. If started early you can burry the difference so it's not noticed and avoid a pie shaped grout line at the top.
I am probably going to use some side mounted L brackets with some plastipaint to cushion and somewhat match. I have two sheets of veneer instead of a wall attached to ceiling mounted cabinets and not much room top add another thicker sheet of wood to anchor with many short wood screws and maybe glue for extra hold. I also don't want to permanently glue my mounting bracket ($40 replacement and sometimes they stop manufacturing the exact one especially since I am putting an uncommon microwave (1.1 Slim or low profile) to veneer. However Microwaves last 4-10 years depending on use, but 7-8 can be expected. With that being said wouldn't need a new mounting bracket if I glued the included on since the remodel is schedule for at least 5 years out and probably 10 years actual.
Flexible Nylon or metal flex support are also being considered for the rear mount substitution since I have a little over an inch limit on support spanning the entire bottom backside of the microwave. Mounting might be a bit difficult since I cant just band the entire back without blocking the rear vent or if I pull tight the nylon and staple through the vent cutout it would be easy but might sag over time with Nylon or metal flex support I would have a rig a ratchet or tightening method.
I really think just two side mounted L brackets maybe a felt slider on them into the side cabinets since a future home remodel with all new cabinets would be best. I might even add the glued mount bracket as well.
MOD note: separated from: [url]https://www.doityourself.com/forum/designing-kitchens-bathrooms/351694-ceiling-mounted-no-wall-over-range-microwave.html[/url]Read More
