Ceiling mounted over-the-range microwave
Old 09-15-23, 04:40 AM
N
Question Ceiling mounted over-the-range microwave
I am probably going to use some side mounted L brackets with some plastipaint to cushion and somewhat match. I have two sheets of veneer instead of a wall attached to ceiling mounted cabinets and not much room top add another thicker sheet of wood to anchor with many short wood screws and maybe glue for extra hold. I also don't want to permanently glue my mounting bracket ($40 replacement and sometimes they stop manufacturing the exact one especially since I am putting an uncommon microwave (1.1 Slim or low profile) to veneer. However Microwaves last 4-10 years depending on use, but 7-8 can be expected. With that being said wouldn't need a new mounting bracket if I glued the included on since the remodel is schedule for at least 5 years out and probably 10 years actual.
Flexible Nylon or metal flex support are also being considered for the rear mount substitution since I have a little over an inch limit on support spanning the entire bottom backside of the microwave. Mounting might be a bit difficult since I cant just band the entire back without blocking the rear vent or if I pull tight the nylon and staple through the vent cutout it would be easy but might sag over time with Nylon or metal flex support I would have a rig a ratchet or tightening method.
I really think just two side mounted L brackets maybe a felt slider on them into the side cabinets since a future home remodel with all new cabinets would be best. I might even add the glued mount bracket as well.
MOD note: separated from: Ceiling Mounted (no wall) Over-The-Range Microwave
Old 09-15-23, 01:31 PM
Received 3,598 Upvotes on 3,227 Posts
Welcome to the forums.
The thread you posted to is very old but highly viewed.
Please post pictures directly to the board of what you are trying to do............... How to insert pictures.
