Shower wall laminate & plastic floor
Old 12-27-01, 08:00 PM
Guest
I'm replacing laminated shower walls and plastic like flooring. I have purchased a fiberglass floor. I will be using tile for the walls.
I assume the laminate is glued on. There are silver bands around each section. Do I pull all this off the walls? Should I put roofing paper around the studs before putting up backer board? Can someone give me the steps to this remodel? The products to buy? Thank you.
Old 12-29-01, 09:19 AM
T
Received 2 Upvotes on 2 Posts
Tiling shower
Go to www.doityourself.com/ceramic for helpful info.
