shower enclosure
Old 02-14-02, 10:47 AM
gaby white
shower enclosure
We are remodeling a bathroom build in the seventies.
how do you remove a fiberglass shower enclosure.
Appreciate any suggestions
Old 02-15-02, 06:17 AM
Received 1 Upvote on 1 Post
If it is sectional, you can pry and peel the sections from the wall. Or if it is one piece and you don't plan on reusing it, you can cut it by repeat scoring with a utility knife in the corners and then peeling it from the wall. Either way if it is sheet rock behind it, it will need to be replaced also.
Good luck
Doug
